dropping oil pan
oi138
Well I'll be dropping my oil pan tommorow to drill in for my oil return line. Was wondering if there is anyway around having to drop the cross member also. Any help would be appreciated.
thanksJames Poe
DaveEEE
Drop the cross member or lift the engine up, those are your options.... When my pan was tapped, they lifted the engine. This caused problems... :eek: My advice to you would be to stick with dropping the cross member.
-david, 93 nsport ka24det
Movingviolation240
Car: '95 Nissan 240SX 400hp SR20DET -SOLD
'93 Lexus SC300 w/ SP66 turbo kit
If you drop the subframe you still have to take the motor mounts off, and then your right back where you started by just pulling the motor up off the mounts. Plus if you drop the subframe there is a lot more crap to un-bolt, and you will have to re-align the car after you put it all back together, not to mention drain the rack and get covered in P/S fluid.....
DaveEEE
Hmph... This will never end Paul. :) But, like I said, after the problems we had with lifting the engine, my shop had reccomended we dropped the sub-frame instead.
-david, 93 ka24det
oi138
I will probably end up just pulling the motor. I mean I've already done it 4 times anyway. (I hate ka's sometimes) :)
James Poe
DaveEEE
Well then, if you have done it before (without breaking the motor mounts like *COUGH*), then I'm sure you won't have a problem.
-david, 93 ka24det
ADAMHU
we just lifter the motor up slightly....
Wolf240SX
Car: Tuning my car, working on friends cars
lift the motor it is easy. I have dont it dozens of times. Just remove the motor mount nuts and jack the engine up till it almost comes off the studs. Then drop the sway bar and pull the pan out it is easy and quick.
