DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Tue Jan 17, 2006 9:12 am
because, a spun bearing doesnt sound like acan of rocks and then it gradually gets louder. a spun bearing sounds first like a belt squeek (very brief, most folks will never even hear it, unless they spin one on start up, like i have) then it sounds like a big beefy hammer hitting an anvil
i've spun bearings in two different motors, same sound
valves wont even make a noise if they are contacting anything, or at least its hardly necessary, and f you did bend valves, chances are your motor wont run at all.
i bent 12. you could crank that thing forever and only get a pop or two, but no running.
maybe its something obscure like a timing chain issue, perhaps a guide has snapped off somewhere. the upper guide is the first to go, the sde one rarely goes, adn ona motor i had a lower plastic one just about to go before i replaced it
but maybe you spun abearing, just go outside and see if its really really hard to crank around by hand
