MinisterofDOOM »
https://forums.nicoclub.com/ministerofdoom-u16506.html
Sat May 10, 2008 10:52 am
It shouldn't cause any problems.The SL max came with 17s anyway. As long as you use the right tires, you won't even see a change in outside diameter so your speedo will still read accurately.
You can tell if you have TCS by looking at the buttons next to the steering wheel. If you have traction control, there'll be a TCS button next to the steering wheel heater button. If you don't have it, there'll just be a blank filler there.
