Sparco Pro 2000 with Bride FG rails. It rocks. So glad I went full bucket. Lots of <3 to Garage Works in Palmdale, CA for getting me this seat. I should have gotten one a long *** time ago.
As far as the install. The bride rails are kinda sketchy. I had to drill out a couple holes on the rail a little bit. I didn't really mind that much because I wasn't using a Bride seat, but what bothered me was that the bolts they supplied were too long. After I drilled the holes out a little bit, I put the bolts in and they were blocking the slider from moving. So I had to dremel about 6 or 7 mm off of the end of the bolts. I don't really mind the extra work, but it just seems strange. And I would have had to do that with or without a Bride seat. But once it's done and I'm cruising around in that seat. Who gives a fsck? hahaha.
