DRL's
ROGUEPLANET
Car: 2012 Nissan Rogue se
I picked up some really cheap DRL's and was wondering if anyone has tried wiring some up?
They pretty much just come with the bare wires hanging off the back.
I was considering piggy backing them off the fog lights, but would rather have them on as soon as the ignition is cranked.
Any suggestions or help would be appreciated as usual.
thanks.
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
ROGUEPLANET wrote:I picked up some really cheap DRL's and was wondering if anyone has tried wiring some up?
thanks.
you gotta go right to the fuse box. the F.B. get power as soon as the "key" is turned.
ROGUEPLANET
Have you seen a plug with a fuse that i could use if i were to go that route?
Im going to go check my local pepboys.
thanks.
ImStricken06
2016 Kia Sorento
ROGUEPLANET wrote:Have you seen a plug with a fuse that i could use if i were to go that route?
you know, normally i never use the plug you are talking about =
http://www.ebay.com/itm/PICO-WIRING-Fus ... e8&vxp=mtr
but, it is a great idea to use that fuse adapter. i simply strip a wire long enough, and take out the cigarette lighter(or other accessory) fuse and slip/wedge the stripped wire into the contact, and then push the fuse back into its respective slot (trapping the wire).
is this the right way to do it? not really lol - but it has worked without fail for me on every car and this idea has gathered well over 300,000miles combined on all my cars.
here an an image of my method. it is in fact a common practice, but its something professional installers will cringe at lol.
Stevies3
How & where did you tap the wiring into? I tried several times to get my DRL module to work with no luck. My goal was to have the low beams kick on when the ignition is turned on.
ROGUEPLANET
Stevies3 wrote:How & where did you tap the wiring into? I tried several times to get my DRL module to work with no luck. My goal was to have the low beams kick on when the ignition is turned on.
I would like more info as well, i am waiting for less inclement weather. Also have to figure how im going to mount the Lights, Its not going to work out the way i was thinking it would.
Image <---generic rogue picture as reference.
I was going to have them inset on both sides of the bottom 3 slots but the lip on the bottom isnt deep enough and the top, you would be able to see my mount screws, i will think about it more while im waiting on a warm day to take the bumper off again.
ImStricken06
2016 Kia Sorento
Stevies3 wrote:My goal was to have the low beams kick on when the ignition is turned on.
you cant do it on this car, by simply hooking up to the fuse box.
you need a whole relay/fuse/switch kit. or you need to completely rewire the whole way your headlights operate.
ROGUEPLANET
Not sure why, but the rogue is starting to look like a catfish to me. Anyone else?
ROGUEPLANET
A N Y W A Y, ha.
SO, i had all the stuff but was waiting for that fuse do-hicky to come in the mail. + time and weather, tornados possible for tonight. :ohno:
I haven't mounted these yet, but put them in place and ran some temp power to see
what it was going to look like.
the lights will set back further than what i have them placed right now and will probably be brighter, but what do you think?
ROGUEPLANET
I also considered getting another set of these and filling in the 3rd slot, but haven't made up my mind yet.
Qashqai
...to be honest, it doesn't look "OEM". It looks like you purchase some cheap LED lamps from ebay and installed in your garage.
But you Rogue's black front grill, side mirrors and headlights looks amazing. I don't think you need some extra add-on lights.
ROGUEPLANET
You know you might be right, and i actually did buy them online and am installing them in my garage, ha, thanks for your honesty, and I do respect the OEM ideal, i get what you mean.
Qashqai wrote:...to be honest, it doesn't look "OEM". It looks like you purchase some cheap LED lamps from ebay and installed in your garage.
Return to “Rogue Forum”
