DRL light on low HID figured out
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
bobybackqc
Car: versa
Hello everyone.
Im new here but i would like to share you someting interesting.
I was looking for a way to get my Day Time Running light working on the Low Beams of my BI-XENON Hid kit since i need thoses in Canada.
Also i dont want to open all my light all the time (dashboard etc)
I can tell you that you can do this WITHOUT modifing,soldering or cutting any wire of the car itselft but wires from the RELAY KIT of your HID Bi-XENON. (Saves you probably the warranty) :confused:
It cost me about 20$ in total an i will finish this tutorial when everyting tested right.
I have used:
1 DIODE
1 5 PIN Bosch Relay
Relay harness (connector to relay with 5 24inches wires)
Soldering iron
Electric tape
A shop manual for the Versa. :facepalm:
You have to know that DRL are working from the Ground of the right headlamp to the Hight Beams fillament then to the left one.
Probably 6volts 6 volts each. :woot:
Return to “Versa Technical Discussions”
