philipa_240sx »
https://forums.nicoclub.com/philipa-240sx-u68765.html
Mon Feb 16, 2009 4:37 pm
Pescakl1,
Refer to the manual EXL section, pages 183,184
The DRL's are controlled through a relay located in the engine compartment next to the fuse panel behind the headlamp. The relay either connects one side of the RH high beam circuit to chassis ground (normal operation) or switches to 12VDC (DRL operation).
You can refer to EXL section, pages 180 for what the the non-DRL wiring looks like.
Here is how I would do this:
1) Remove both high beam bulbs. This is necessary to isolate the wiring for step 2 below.
2) Locate the ground lead in the plug for the RH high beam lamp. Using a multimeter, confirm that there is continuity to ground with the DRL's OFF and 12VDC when the DRL's are ON. If not, you have the wrong wire.
Note: The FSM indicates the wiring we are looking for is in the RH high beam, but it could be in the LH as well. BTW, left/right as when sitting in the vehicle.
3) Cut this wire about 4-6" from the lamp socket. Connect the lamp side of this wire to ground. The remaining cut wire is your 12VDC switched source for your angel eyes.
