Larz »
https://forums.nicoclub.com/larz-u216291.html
Wed Jun 12, 2013 11:18 am
If I am correct, your DRLs actually use the high beam bulb itself, but at a lower brightness. That is to say there isn't an extra bulb in that housing that is used only for the DRL feature. Our American models, being years behind the rest of the world (on this issue), just use a straight-forward high beam bulb and did not come with, nor were required to come with DRLs. The only way I can work out to use the fogs as DRLs would be to purchase a DRL fog 'kit' with it's own module that makes them light while the engine is switched ON. Then, disconnect whichever module your car is using to power the high beam bulbs when the engine is on and hope that dosen't prevent you from using the high beams for ... high beams. You technically haven't broken any laws because you are displaying DRLs, just not the ones your car came with. I doubt law enforcement would even give your car a second look, and if they did, you can prove they are bona fied DRLs, and you aren't simply driving with fogs switch on.
Have a look at my pics in my sig. I added Phillips DRLs with an included module that simply hooks to the battery - no special wiring needed. They work great and are mounted nice and low near the fogs. Get those, unhook your DRL modlue and job done!
It seems a huge time consuming effort with re-wiring, removing the lower grille trim, mounting the kit in the wheel well, etc. Hardly seems worth it just to make the fogs into DRLs. Since you live in Canada where fogs are actually useful for safer driving, would you want to lose the benefits of an actual fog lamp?
You can also change out the high beam bulb for a nice 3000k amber colour to make your existing DRLs stand out. If you never actually use the high beams (I never do), it won't be an issue and you will still have fogs to help drive through ... ermm fog.
