driving with sr for the 1st time is this normal
Justicc86
Car: anything to do with cars
Got my sr install complet . Drove it down the road a little bit to get a feel for the new ACT clutch and started to notice a prolem. The problems is that anytime I crank my car or let out the clutch with out giving it enough gas the turbo seems to hit the steering shaft my ? is Is this common and is there anyway to prevent it from happing or do I just deal with it ? And yes the lower heatshield is removed from the turbo and AIV is removed and pluged
(sr redtop in 95 240)
I H8 UR DSM
Is it loose? it should move..are your motor mounts good?
Justicc86
problem fixed downpipe was loose and had an exaust leak car runs strong and is very powerful
another qustion does anyone know what wire to tap into for a/f gauge on o2 wire :)
Spidey
Car: my car
its a white one but tap in to it on the wire between thw ecu and the plug Not between the plug and the sensor.
Justicc86
thanks that would be why my a/f gauge doesent work
WhItES13
Dont mean to hijack the thread but ,Justic where and how much did you get your motor from? Did you do the install it yourself if not who helped you? I live in Gulfport plan on doing mine over the summer! 2nd SR that i know of in MS.Thanks!!
Justicc86
I got my motor from "kid zelda"(I think thats his screen name) for $2200 plus shipping(very cool guy to deal with) Me and some friends of mine did the install here in hattiesburg at the shop I work at. Took about a week of work and running around to find parts. the install was fairly easy to do and saved me about $1000-$1500 labor.
