driving triptronic
General discussion area for the L32-chassis Altima
frosty606
Car: Nissan altima 2.5s coupe
is it ok to drive trip all the time? like as long as i **** right? or will it **** up the engine? and what if i put it in neatrul alot?
marlin29311
Car: 2008 Infiniti G35x
Driving in manual shift mode all the time is fine, it won't harm the engine. There is a limiter when you are in manual shift mode so you can't even red line the engine. Putting your car in neutral while driving is a bad idea however - don't do it.
Nicky Altima
Car: 2008 Nissan Altima
Just curious..why is it bad to drive in neutral?? Cos I do it all the time when going downhill...
guitarist982
Car: 2008 Nissan Altima Sedan 3.5 SE w/ CVT
Nicky Altima wrote:Just curious..why is it bad to drive in neutral?? Cos I do it all the time when going downhill...
It's not the car being in neutral that's bad ... it's going from drive to neutral and vice versa while moving that will wear on the transmission.
Why do you put your car in neutral to go down a hill?
realmac
Car: 2016 Nissan Maxima SV
I believe that is a strategy hypermilers user to get better fuel efficiency.
eddie2.5
Car: Nissan Altima
i also wondered when driving it in manual mode should you treat it as if it were a manual car meaning ..... as you are about to shift should you let off the gas peddle then shift then gas it again or just always keep the gas peddle pressed?
jdshift
Car: 2019 Nissan Altima
2015 Nissan Altima 3.5
2014 Infiniti QX70 S 5.0
You could do either or.........floor it to shift, and letting off the gas to shift. Has more of an manual feel though when you let off the gas to shift it. The triptronic has that limiter that will shift regardless.
Nicky Altima
realmac wrote:I believe that is a strategy hypermilers user to get better fuel efficiency.
That is my exact answer..haha..there is this long stretch of road that goes down hill and I usually switch to neutral..guess I won't be doing it anymore now I know it's bad for the transmission..
marlin29311
You actually get worse gas mileage from doing it too - do some research on the net from actual car websites, not websites filled with yacko's that think they know how cars work...
gmont02
Car: 07 altima sedan
yacko's wackos....
Return to “4th Generation Altima Sedan (2007-2012)”
