silver2k2 wrote:I know they are not supposed to reach out past the headlamps, but I see very little peripheral lightning taking place. I was wondering if my are adjusted wrong or it is the same with all 94 Qs
I dont think I will be trying the silverstars
http://www.danielsternlighting....html
It shows here how they have less light output measured in lumens then a standard bulb.
I will probably just leave it alone and replace the low beams with these HIR bulbs
http://www.hirheadlights.com/FAQs.htm
Actually, silver, the fog lights not only won't reach out further than the headlights, they won't reach anywhere near as far. The low beams illuminate pretty far. Fog lights only reach out maybe 25 feet at the most. That's all. Maybe not even that far.
If you pulled the low beam bulbs and saw the distance the fog lights illuminated, you'd be surprised. The light that close in is pretty bright, and also covers the area alongside of the front of the car quite a way, and brightly. But you are NOT going to get any distance with them. The reflector determines that, and no matter how bright you make the light, it won't change the beam pattern.
I love the fog lights for running curves in the mountains, and often, just plain old curves because of the way they light up the side of the road. But if you want to supplement thefactory head lights fir distance, you might want to replace the fog lights with long range driving lights. Be advised though, that it's going to be a challenge, especially if you want to be able to aim them, which is critical for long range driving lights. That will require custom fabricated mounting brackets and considerable very careful surgery
100 watt bulbs in your high beams will greatly improve them, but as best I can recall, the G50 uses a single multi-watt bulb. You probably have 100/55 watt bulbs since you changed them, maybe 100/65, depending on which ones you got. If you want to use a relay, which is available with a wiring kit from DSL, you can get 100/80 watt bulbs. They will improve your low beams and keep the improvement you got with your high beams. You can also consider the H1R bulbs that Daniel Stern sells. He can recommend the best way to go. While unfortunately, thanks to the reflector limitations on my F50, they didn't extend the range very far at all, they did increase brightness within the existing pattern. They didn't solve my problem of not enough range, but they did improve illumination within the range the OEM bulbs have in the factory reflector. Keep in mind that while changing to HID sounds cool, unless you change the reflector, you could lose more than you gain, as HID bulbs work differently than conventional halogens. This is a major project, regardless of how many guys here tell you it's easy and effective. I strongly urge you to discuss this at length with Daniel Stern. I think he really knows his stuff, and can advise you as to what will work and what won't, as well as how to accomplish whatever you decide on.
BTW, you're lucky. The G50 DOES lend itself to headlight improvement. The F50 does not. I'd LOVE to add auxilliary long range driving lights to my '05 Q45, but there's just no good place to put them where they wouldn't look goofy.
Good luck, and let us know as you progress.
