Driving in AUTO... Why do I vibrate on the highway?
Freyspath
Car: 2003 Nissan Pathfinder LE
So I have been meaning to ask this for quite some time.
When I got my Pathy, I noticed the 4wd system had 2wd, auto, 4hi, and 4lo. Very cool stuff! Much better than my 4wd and Low range options on my explorer.
Auto I noticed just drives the car in "All wheel drive", 2wd does just that, and 4wd hi/lo are true 4wd.
My question is though, if you drive the car in AUTO why does it starts to vibrate after you go faster than 50mph? I tried it the other day on the freeway, and when I switched to 2wd the vibrations stopped.
Why is that?
Does it hurt the car to drive it in AUTO all the time? (granted I do drive the car 90% of the time in 2wd)
WINNIPEGS_MOST_WANTED
Had mine to 75 mph on the icey highways last week in auto. No vibration here.
...and yes; it was probably a bit fast for the conditions
QX4ME
Car: 02 Infiniti QX4 4WD
11 MB C300 Sports
06 Honda Odyssey
My understanding is it is OK to drive in AWD all the time, which is the same as 2WD if there is no slippage.
I use AWD only when road is wet.
t_b0ne3
Car: 2002 Infinti QX4 4wd My first Nissan was a 1985 720 4wd P/U. My other ride is a 2005 FXDWGI
Just drove mine this past week in auto and it's no different than 2wd? I'm thinking you may have a bad cv joint up front? Could be something else maybe fueler could help out with this??
Freyspath
Well I usually only drive it in AUTO when the roads are wet, but when I wanna go on the highway and its.... raining, or wet, the moment I pass 50mph the car gets all these vibration buildups
naladude911
Car: 2001 Infiniti QX4
No point using AUTO only for snow imo. I use 2WD even in snow, and until I start slipping do I put the car in AUTO. I only use 4HI/LO if I am driving in deep snow or I get stuck. AUTO eats up MPG as well.
bmlawless
Car: 1999 Infinity QX4
I have no vibrations when driving at freeway speeds in AUTO. I've seen claims that AUTO is identical to 2WD until it starts slipping, but I truly believe there is a difference. My MPG goes from 14.6 to 13.1 when I drive in AUTO. A couple of weekends ago we were on a road trip and when coasting, I could feel the difference in drag when I switched AUTO on/off.
Pat Connelly
Car: 1997 Infiniti QX4
Check the U-joints on the front driveshaft.
