Driving in 4H
RyanEvh
Car: 2001 Nissan Pathfiner
I believe it says in the owner's manual that you should not exceed 80km/h (50mph) while in 4H. I've gone above 80km/h while in 4H but you will only lose traction right? Also, can anything be damaged by going over the recommended speed in 4H?
TheReplay
not sure on the damaging part, but my better judgment tells me that if your using 4hi for whatever reason (snow, offroad) you probably shouldnt exceed 50mph in terms of safety.
alexf20c
Car: '00 SE 4x4
i agree. if road conditions are that bad that you NEED to be in 4wd, then you probably shouldn't be doing 50mph.
QX4ME
Car: 02 Infiniti QX4 4WD
11 MB C300 Sports
06 Honda Odyssey
RyanEvh wrote:I believe it says in the owner's manual that you should not exceed 80km/h (50mph) while in 4H.
The owner's manual says that do not do that speed in 2 position, and do not shift into 2 position when speed is over 50 mph. It does not says any speed limit in D position.
alexf20c
Car: '00 SE 4x4
you make no sense.
regardless, this is a direct quote from the owner's manual:
Quote »The 4H position provides maximum power and traction. Avoid excessive speed, as it will cause loss of traction. Speed over 50 MPH (80km/h) in 4H is not recommend.[/quote]
QX4ME
11 MB C300 Sports
06 Honda Odyssey
You are right Alex. I found I was reading in a wrong section about the speed limit. Sorry about that.
miamiheat3332
Car: 2002 Nissan Pathfinder SE - 2006 BMW X5 4.8is - 2001 Audi A4 1.8T Quattro Sport
well is it just not recommended in terms of safety or what? if it can screw up parts, obv then thats not good, but if they just mean safety id like to know if you can go more than 50.
KyooX4
Car: 2001 Infiniti QX4 4wd
Why would one ever need to go over 50mph in 4wd?
alexf20c
Car: '00 SE 4x4
they just don't understand, KyooX4. lol
mechanically, there's really no issue in running 50mph+ in 4WD, assuming you have the same size tires front and rear.
why you would need to do 50mph in 4WD is beyond me.
RyanEvh
I was asking because about a month ago there was a snow storm and I had to go on the highway so I put it in 4H and went around 80km/h. So I was just wondering if any damage could occur if I go above that.
alexf20c
Car: '00 SE 4x4
nah, you're good to go. it shouldn't hurt to shift from 4H->2H at 80kph. just don't shift from 2H->4H, even with the electronic transfer case.
if you have the manual shift transfer case, then i would've just shifted from 4H to 2H, because you can shift out of 4WD at any speed.
K03sport
Car: 04 Pathfinder. My first Nissan was a '72 Datsun 510 Wagon.
milage will suffer slightly at highway speeds in 4H, however, we've got our best mileage to date in 4H. The trick is to avg 35-40mph for 8 hours. Engine is below 2500rpm and wind resistance isn't working against you.
korbeano89
Car: 1997 Infiniti QX4
i drove for over 60 miles going around the speeds of 60 and 70 mph in the 2wd but i had the switch in 4 wheel lock, is that what you did? but anyways its not bad bad but its not good either, i did that a couple months ago and everything seem to still be doing ok, knock on wood lol
