Shaefer Thomas »
https://forums.nicoclub.com/shaefer-thomas-u15115.html
Wed Aug 10, 2005 3:10 am
Hey guys,Im planning on doing almost and entire drivetrain upgrade this weekend. Im planning on putting a J30 LSD, S14 lower mileage trans, Spec stage 3 clutch, and Spec aluminum flywheel into my 92 coupe.
Now, my question is, what should I replace while I have all that stuff out as far as bearings and seals?
Im planning to change the fluids in the diff (80W-90) and the transmission(full synthetic), and the clutch kit I bought came with a new release bearing.Anything else that I should pick up before I start tearing this stuff apart? I appreciate your help!
Also, does anyone know if the stock J30 diff mounting bolts will work on the s13 as well? I was told to buy m12 X 1.25 x 85mm bolts, but thats exactly what the stock J30 bolts look like. Again, any help is appreciated.
