s13sr20chris »
https://forums.nicoclub.com/s13sr20chris-u7880.html
Mon Jul 05, 2004 11:36 am
rear end will last 1,000,000 if you just keep gear oil in it and water out. carrier bearing is not a common failure but mine got wet and took a dump. by the way the auto carrier bearing will fit on a manual driveshaft:) . trans is not a bad trans but not extremely tough either. thats ok because even a hewland racing gearbox will wear out in a day of driving if you dont shift right. protecting your trans is all about good fluid(i reccomend redline mt-90, never use mobil 1 gear oil in m/t), and shifting like a reasonable person. i would look into the clutch though. the stock clutch may not last too long with a turbo.
