IvoryJ30t »
https://forums.nicoclub.com/ivoryj30t-u9485.html
Sun Jul 11, 2004 9:35 pm
the tires, rear end, transmission all affect the rpm at a given road speed.
final drive ratio is the ring and pinion [rear end in a RWD car].
to figure the road speed at engine speed, you need the variables.
rpm-3000 rpm, lets say 3rd gear is 1.302:1, final drive [rear end] is 3.916, and you have a rear tire size of 255/40-17
3000 rpm into the transmission- through 1.302 gears equals 2304.15 rpm. [3000/1.302=2304.15]
now the transmission is turning the driveshaft at 2304.15 rpm, which turns the rear end input {[differential] a front wheel drive car doesnt have a rear end diff. in that case the differential and final drive gears are intergral with the transmission. the diff in a FWD car turns the axle shafts}
with 2304.15 rpm input at the differential, the 3.916 ratio final drive turns the wheels at 588.39 rpm [2304.15/3.916=588.39]
for a 255/40-17 tire- 255 mm * .40 [aspect ratio] = 102 mm sidewall.
102/25.4 [mm per inch] = 4.016 inches.
4.016 * 2 [2 sidewalls [top and bottom]] = 8.032 inches. 8.032 inches + 17 inches [wheel diameter] = 25.032 overall diameter.
25.032 * 3.14 = 78.6 inches per tire revolution.
78.6 inches * 588.39 rpm = 46247.45 inches per minute.
46247.45 / 12 [inches per foot] = 3853.95 feet per minute
3853.95 fpm * 60 [minutes per hour] = 231237 feet per hour
231237 fph / 5280 [feet per mile] = 43.79 miles per hour.
therefore, with the above specs, this car would be travelling 43.79 MPH at 3000 rpm in 3rd gear.
