OK, we got the motor and trans mounted. I'm at the point of bolting the driveshaft back up; I go to put the yoke (I'm assuming this is the yoke, it's a cylinder that slides into the RB20 trans and has a thing on the other end with 3 holes to bolt up to the driveshaft) back into the trans, and it hits this thin-walled metal cylinder that comes off the back of the trans, so the yoke won't slide in all the way. Am I missing a part? This metal cylinder doesn't look like it's doing much, should I cut it off so the yoke will go all the way in? Someone, please share your experience with me
