driveshaft too short
andre's240
Car: 1990 240sx s14 KA swapped
hey guys i have a 90 240sx that use to have an sohc i swapped in a dohc from a 95 s14, i got the drive shaft off the diff so i could slide it into the trans but when i did so there is a fingers width of spacewhere the spline goes into the trans..is this supposed to happen or am i doing something wrong? need help asap!
biggie
Did you swap transmissions? S13/S14 have different dust shields on the back of the transmission and that could be the difference.
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Also which driveshaft are you using?
andre's240
its the s14 transmission and the driveshaft is just the stock 90 driveshaft...but everywhere i look says it should fit fine
biggie
Probably the S14 dust shield has been removed, making it look shorter.
Only way it should be actually shorter is if you were using an ABS DS on a Non-ABS Diff.
Some pics may help.
andre's240
ill takesome afterschool today and post em up
andre's240
biggie
Does look like the S14 dust shield has been removed, probably ok.
Mine with shield.
Then without
There is a gap
andre's240
Thanks man.. just looked at my old transmission and its got the dust boot so ina put it on the s14 transmission
