fufanu180 »
https://forums.nicoclub.com/fufanu180-u155710.html
Mon Mar 08, 2010 4:55 am
This weekend I did a motor swap and everything went well except the driveshaft. The KA driveshaft won't button up to the SR transmission so smoothly. There is about 1 1/2 inches that still pertrudes from the transmission and the damn thing just won't go in any further.
It also doesn't help that I have a J30 diff that is 3/4 of an inch longer than that of the original KA diff.
My thoughts are that if the drive shaft is as far as it will go into the transmission and and somehow I were able to get the shaft on the diff then once I lowered the car the shaft would just ram up into the transmission more, possibly messing something up. The shaft needs room to flex so that when you hit a bump it has room to move with that bump.
I'm completely lost.
What would be my possible solutions?
Is there any way I could come a cross an SR yoke that would slide in the butt of the transmission just right?
