driveshaft????
Beastin_RB
Car: 1995 240sx RB20det swap
ok my car makes a weird poppin noise sometimes. someone told me it may be the bushing in the 2 piece drive shaft? how can i tell and where is a good place to get a one piece? oh and is it a stock s14 driveshaft in my rb20 swap? thanks
derek
Azrial
Car: 93 240sx vert, 1990 pignose hatchback roller
Where is the popping sound from and when is it making the sound? During shifting? During deceleration? When you hit a bump? When you turn? You can usually find a link to a place that makes one piece drive shafts on here. One of the advertisements I saw last night was for a driveshaft place.
http://www.shaftmasters.com/
Beastin_RB
it usually happens when you let out of the clutch. or if i grab 2nd hard and spin it does it then alot.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Subframe bushings, loose diff bolts, trans mount, or worn U-Joints on the shaft would be my guess.
Beastin_RB
well the guy i bought it from said it was subframe bushings. but then someone else said driveshaft. is there anyway to look and tell?
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Yeah, get the car in the air and check under it. Try to wiggle the diff, then try lifting the sub-frame up and do and see if it moves, also tr rotating the DS and see if there is a lot of back and forth play
Beastin_RB
when i changed the oil the other day i looked at the ds and it had some play in it and when i moved the first half the back half didnt move. is that normal or what?
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Play is normal, about 1/8 inch of play.
Beastin_RB
ok well then i'm not so sure its the driveshaft. seeing as the subframe bushings are the cheaper of the 2 i may try that one first
