If I keep bouncing it back and forth, it slowly moves the car, but it gives the same result no matter what gear I'm in. It's almost as though the transmission won't come out of gear. Any suggestions? The transmission has been out of the car for 3-4 months while I've been building the motor.. New clutch and pressure plate, throw out bearing, pilot bushing. Changed transmission front oil seal and upper Gasket. Nothing that should be affecting it
