Driveshaft slip yoke, Frontier
Fimaf
Car: Nissan Frontier
How often do you service driveshaft slip yoke? It feels like the driveshaft has a slack when starting from dead stop... I've heard that the slip yoke is binding and needs to be lubed. Does anyone have similar problem? Suggestions?
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
it should be getting lubed by the fluid in the transmission and generally doesn't need servicing unless the seal is leaking.
There's always a little slack - most of it is lash in the ring and pinion gears in the rear end. The slip yoke goes onto a splined shaft and should have very little wiggle, but you can check it by unbolting the driveline from the rear axle and twisting by hand.
Fimaf
It's a two piece driveshaft, and slip yoke is in between the two pieces... there is no trans fluid in there. Some people says that it needs to be re-greased once in a while. I am getting a slack or thump when I press on gas from complete start.
Desert Rat
2017 Frontier 4.0
2008 Boulevard C90T
Ah. Is this a D22 Frontier or a 2005+? If it's an early one, swap in a 2001-2004 single piece driveshaft and get rid of the carrier bearing.
Fimaf
It is 2005+, two piece driveshaft. I also heard traction bars would solve the problem, but nobody knows for sure. Every time I press on gas pedal, there is a slack or bump.
Phaggerty6
Car: 2010 Frontier 4.0 liter 4x4 Pro
2010 4x4 Pro. Same symptoms when putting her into drive. Later developed a clicking noise I could hear at very slow speed. It was the front drive shaft. Got a new one manufactured by TRW. One piece. Problems solved.
