mouse53 »
https://forums.nicoclub.com/mouse53-u73590.html
Sat May 27, 2017 12:08 pm
Anyone know how to rebalance the driveshaft if you forgot to mark the center flange when replacing the carrier bearing? I marked everything but the flange before I separated the 2 drive lines and now have a bad shimmy/vibration. I have removed the shaft, changed flange position on the front shaft 3 times now and still have vibration. Tires are about 3 months old, blocks and pinion position are good and raised the carrier about 3/4 ", and u-joints are good, But the front joint on the rear shaft is stiff in one position, easy on the other. Like move easy side to side, but up and down tight. I didn't think it would make that big a difference. Sorry wasn't trying to highjack this thread, but couldn't find info anywhere else.
