OutToWinPAHC wrote:burning out the tail shaft seal.... Or carrier bearing.... Remove and inspect
Tail shaft seal, maybe, since the driveshaft is being pushed forward from the extra legnth of the diff, but it only appears to be leaking from the shifter hole (missing C-clip, and gasket is non existant). However that really annoying noise SEEMS to be that the driveshaft is rubbing agains that metal circle thing, which appears to be there for the purpose of protecting the seal
carrier bearing sounds like it might be more likely... which would explain the left to right shaking, but wouldnt explain the noise, or the smoke... possibly a combination of both?
It possible to replace the carrier bearing if bad, without changing that piece of the driveshaft? It seems like its attached, but i dont know
The only reason i dont want to put in the ABS driveshaft, is cause the only one i can find around here, the guy wants $100 for. Thats money i dont have, and driveshafts usually go for about $40 around here. That, and i dont know for sure if that would fix the problem, it could be another issue, something stupid
Either way i cant drive the car more than 15 minutes at a time without feeling like im gonna pass out, so i wanna fix this asap. Im trying to convince them to let me get the car on the lift for half an hour before the end of the weekend so i can see whats going on
