driveshaft rubbing against end of transmission help plz!!!
jazz4890
Car: 1991 Nissan 240sx
I just swapped in an sr20det and for some reason when I drive the 6 bolts that hold the driveshaft to the transmission are rubbing against the rubber end of the transmission I used the yoke end piece from the ka transmission I am wondering if that makes a difference and may be causing the driveshaft bolts to be rubbing against the end of the transmission.
jr_ss
Car: 95' S14
You didn't take that dust cover off did you... If you have that piece that extends out from the back of the trans it needs to be removed. I don't have a picture of it, but it is pressed on the back of the tail of the trans.
jazz4890
if you had a pic I could understand a little better I will try to take a pic tomorrow of it and I know there is a piece that looks like an octagon that I used to hold the transmission and driveshaft bolts together
Justin35ll
Car: s13 coupe sr20det
What driveshaft to transmission bolts? It's a slip yoke it just slips on.Rubber end of the transmission???
jazz4890
yeah the yolk slides in but the opposite end of the yolk where it bolts on the driveshaft with the rubber spacer in between i will take pics tomorrow to show the piece.
Beems240sx
Car: built S14, E30, R6 raven
im having slight issues with mine too. please get pics!
jazz4890
does anyone else know any other things it could be and i am going to take a pic tonight to show whatit looks like.
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
it's the dust collar, when you swap you either run with out one, or you can do what i did and remove what you need to so you can use it (sawzall is your friend).
gmac708
Car: :o)
1970 Datsun 240Z
1972 Datsun 510
I comes off really reasy, just tap with hammer.
jazz4890
thanks for the help guys I got that piece off and it worked thanks for the help and I am wondering why do they even have that piece on the transmission if it just rubs the driveshaft?
Blown240sx
Car: 1996 240sx
The SR and KA drive shaft input shafts are slightly different. YOU can cut the dust cover to keep it if you want.
