DGA »
https://forums.nicoclub.com/dga-u13015.html
Fri Mar 12, 2004 9:30 am
Unbolt the flange on your rear diff first (Also mark the location of the flange compared to the diff. before you unbolt it.) Next, unbolt the center bearing from the underbody, and just pull the driveshaft out of the transmission. Place a pan beneath the *** end of the transmission, because fluid will come out even if you drain the transmission.
