driveshaft question need asnwer
costa_rican13
Car: 1993 s13 coupe
i got a j30 vlsd with the damn sensor on it, which my car isnt abs. so i know i need the abs driveshaft because my non abs will take up the slack but cause me to have to keep replacing the rear main seal every couple months. now i can get a s14 auto abs driveshaft for 30 bucks. so will the s14 driveshaft fit on my s13?? i have a 5speed as well not auto. thank you for the help guys
poshatch
Car: p.o.s. 1990 240sx hatch
i think the drive shafts for auto and manual are different and not interchangable
why exaclty is there an issue with that sensor now? im sort of confused
slidestyle69
Car: 92 s13
you cant run an auto driveshaft
the sensor on the diff doesn't matter.
i have never had a problem running an abs or non-abs shaft with any of my cars with a j30
poshatch
slidestyle69 wrote:you cant run an auto driveshaft
diddo thats why i was sort of confused as to why he would even bother with it haha
costa_rican13
Car: 1993 s13 coupe
reason being guys is that from what ive learned from searching is that the non abs drive shaft is like .75" inches to long if the j30 vlsd has the abs sensor. now i can use my drive shaft i have now, which is the 5 speed non abs. which will end result to me replacing my rear mainseal every couple months due to the pressure or stress or something from the driveshaft being too long. now this may be incorrect but ive searched and a few said that they have had those problems. but also some ppl have a prefect fit with the non abs shaft even with the dif having the abs sensor ring. im trying to avoid all these problems by just getting the abs shaft. so therefore i will have a perfect fit and not have to have any problems and 0% downtown in the future minus the regular maintance and such. hope im not confusing.
poshatch
i see wat your getting at...no you really should be ok the diffs shouldnt be that much different because from what your saying the abs diff is longer than the non abs diff but i dont think it is
Chris28
Car: 92 s13 KA-T
Just do it, nothing will happen. Since the rest of your driveline is probably stock, the mounts will soak up the extra length.
poshatch
yeah i understand though why he asked cause i mean if i read that the swap could potentailly damage the transmission seal id deff have that clarified before i went ahead with the swap
funny how that incorrect info is floating out there since this is sucha common swap for s chasis
costa_rican13
Car: 1993 s13 coupe
ok well if guys say it wont matter, then i will trust you guys on that. just hope i dont gotta change the damn seal out. cause im inexperienced with the transmission. so if something goes wrong. i may be out of luck. hopefully im one of those guys that can say "i 've been on my vlsd for 2 yrs now, no problems for me here"and thanks for the help guys. it is appreciated. :bigthumb:
slidestyle69
Car: 92 s13
go to a local drive shaft shop and get a 1pc made...mine ran me about 80 bucks....best thing i did to my car in a while
poshatch
slidestyle69 wrote:go to a local drive shaft shop and get a 1pc made...mine ran me about 80 bucks....best thing i did to my car in a while
your joking!
i cant get anybody around here to do one for me for less than like 200
slidestyle69
Car: 92 s13
really? that's crazy. I guess Alabama does have its benefits some times lol.
rednecks and there drive shaft shops here :chuckle:
JayArr
Car: 1990 Nissan 240SX Coupe
Why don't you take the LSD innards out of the ABS casing and put them into your non ABS casing?
Then your lengths will all be correct and you will still have LSD.
JayArr
Didderson
Car: 1990 Nissan 240SX FB
'88 Nissan Hardbody pickup
'74 Datsun Z
JayArr wrote:Why don't you take the LSD innards out of the ABS casing and put them into your non ABS casing?
JayArr
That's what most people do which is why you're confused as to the lack of information on this swap LOL..
I have a stock manual s13 shaft if u need it get in touch.
costa_rican13
Car: 1993 s13 coupe
ok well driveshaft shops here charge out @55, and idk how to swap internals, and dont feel like wasting my money messing everything up cause i didnt install right. and i also already have a driveshaft, its a s13 5 speed non abs. because my cars non abs and a 5 speed. plus im not really on the free spending side as well... i work at starbucks.. not to getting to much money. so thats why im trying to go inexpensive.
poshatch
costa_rican13 wrote:ok well driveshaft shops here charge out @55, and idk how to swap internals, and dont feel like wasting my money messing everything up cause i didnt install right. and i also already have a driveshaft, its a s13 5 speed non abs. because my cars non abs and a 5 speed. plus im not really on the free spending side as well... i work at starbucks.. not to getting to much money. so thats why im trying to go inexpensive.
haha i got alot of friends that work at starbucks so i know how it is haha
swap the diff and use the s13 cover and you will be good to go man
