biggie »
https://forums.nicoclub.com/biggie-u182.html
Thu Sep 23, 2010 8:51 am
I doubt the yoke would fit, but you can try. I would assume the length of DS would be different as well. Given you're putting this much into it, I'd order a 1-piece alum DS from a sponsor, they should be able to do custom length if needed.
For S13 vs S14, easiest way would be to see if there is a CAS hole in the top of the bellhousing right at the motor, if there is a hole S14, if not S13. Though either will work and is almost the same length (S14 has a goldish metal dust cover pressed into the tailshaft, that can be removed easily if needed).
