vliou wrote:What's the general concensus here on using AUTO in the dry (especially with full lock turns at the local McDonalds?)
The general consensus is that you're only supposed to use it in slick conditions, and never in the dry.With that said, the manual and the placard on my sunvisor say differently -- that it can be used on slick or paved roads. . it's basically Attessa-ETS which is sold on several Nissans / Infinitis, and is engaged 100% of the time.With that said, however, the drive train on the other vehicles are are all entirely different.
I've never had a real binding problem, or problem turning in the dry with AUTO as opposed to using 4hi, which def. will stop the vehicle in its tracks at the drive thru.
A week after owning it, I was actually screwing around in the Arby's drive thru and engaged 4lo man was that rough.
