everything went in smoothly thanks again240life wrote:If the transmission is a SR unit you need to knock the dust cap off of the transmission. If you are using a KA rear section on your transmission you will need to trim some of the rear off of the transmission so your shaft can slide in further....the KA transmission is slightly longer
