driveshaft lengths
240DRFT
what are the lengths of the 89-90 auto and manual, 91-94 auto and manual and 95-98 auto and manual driveshafts.
the reason i ask is because i have a 90 240 and i swapped in a 96 ka/transmission and the transmission is about an inch or two shorter than the sohc's transmission. thanks.
240DRFT
i dont know if abs or hicas matters, but just adding those in
justmerging
Car: 07 Versa SL w/CVT Cuz I'm lazy
abs/hicas are one in the same(they came on the same cars as a package). The main difference is in the rear end. For your application you just need a manual transmission driveshaft from a 91-94 car and it will bolt up(unless your running an abs/vlsd rear end).
If you really want me too I can go measure my auto/ABS s13 driveshaft for you. It's just laying on the floor of my garage.
240DRFT
so its just that sohc trannys and dohc trannys are different lenghts?
do i need the whole driveshaft or could i use like just the front half or rear half? also what if i want to get a vlsd? thanks.
i dont need u to measure it, thanks though.
matt4pl
Car: cars, anything fast, graphic design, lots of stuff
all 240sx manual trannies are identical, period, its the rear diff where the differences are
FreeRunS13
Car: 1991 nissan 240sx
are you doing the transmission conversion?
240DRFT
i had a ka24e, then i put in a 96 ka24de, and now the driveshaft is too short
FreeRunS13
the automatic driveshaft is shorter than the M/T driveshaft so that could be the problem
240DRFT
i didnt have an auto, and the new one isnt an auto either
FreeRunS13
what driveshaft are you using?
240DRFT
the one that came on my car. 90 240sx manual
FreeRunS13
from what ive heard you cant use the s13 drivshaft with the s14 transmission so im guessin thats why. but if you find out something else let me know
240DRFT
it fits and works. ive been drving it around. it just that its about an inch too short, so it drips fluid, but very very little, very very slowly.
