Driveshaft Install Woes
whiterw
Car: 1991 300zx 2+2
I've already taken the old driveshaft out.
The new one will not slide into the transmission. I have tried everything I can and even tried installing the old one.
Are there any tricks to getting this done? I'm at a loss.
The new Driveshaft is one from Conceptzperformance.com its from Inland Empire.
There seems to be a piece of rubber around the spline that wont budge.
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Is it the right one? The splines are different for the N/A and TT. Count the splines on both the old one and the new one. If there's a different count, there's your problem.
To clarify, the old one still fits fine, right?
whiterw
Car: 1991 300zx 2+2
the old one won't fit either. and the splines are the same in both driveshafts.
t.mcginley.jr
Car: 2002 Nissan Altima SE 3.5
1990 Nissan 300ZX NA 2+0
1966 Ford Mustang
Did you lube the end of the shaft with trans fluid? Either way it should slide in pretty easy. The splines have to live up so you usually have to rotate it some to get it in. If it still won't go in, there might be something wrong with the rubber end seal?
whiterw
Car: 1991 300zx 2+2
maybe.. it doesnt make sense that the old one won't go i either. I'm thinking the splines weren't lined up correctly.
Shoey2
Car: 1990 300ZX Fairlady Z Twin Turbo
it may have a master spline. when you checked the spline count was there one that was larger then the others? like a spline that was about 2 normal splines wide in 1? i bet thats what it is...also a few drips of trans fluid on the splines would definitley help
whiterw
Car: 1991 300zx 2+2
Hopefully getting the master spline lined up right. I saw tha but didn't know it's treated that much. Luckily this isn't my dd
whiterw
Car: 1991 300zx 2+2
problem solved. the angle we were working with wasn't good so we removed the sway bar and differential brace.
t.mcginley.jr
1966 Ford Mustang
whiterw wrote:problem solved. the angle we were working with wasn't good so we removed the sway bar and differential brace.
Awesome! :bigthumb:
