driveshaft install help
skirodeo7
Car: 2007 Nissan Frontier, 1991 Nissan 240sx
Trying to put the SR driveshaft into my newly swapped 240. However, I can't get the damn thing into the transmission splines more than an inch, maybe and inch and a half. The FSM is again no help as it merely states to "install driveshaft into transmission"
Thanks.... I figured that much.
Anyone have suggestions? How did you do it?
Edit: I noticed that the splines on the transmission run all the way around the shaft, but there are two splines missing from the inside of the driveshaft yoke. Do these need to be mated up in some specific manner in order to slide this thing all the way on? This is frustrating. I can build a motor, but getting a driveshaft in is what gives me the most trouble? sweet f-ing christ!
Modified by skirodeo7 at 6:57 PM 1/11/2009
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Most of the time drive shafts are keyed. My GM to nissan one is. Get a flashlight and look into the trans.
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
You've probably got the right one already but I'm gonna ask which dust collar do you have on the transmission, the KA or a SR one? Just throwing out ideas.
skirodeo7
it's the SR transmission out of my front clip so I'm assuming it's the SR dust collar. I didn't replace it so I imagine it's the Sr one
EDIT: I should also mention that the driveshaft isn't even touching the dust collar right now.it wont go far enough in
Modified by skirodeo7 at 9:28 AM 1/12/2009
Schrute Farms
Car: 93 Datsun 240sx
You know when I am mating a trans to an engine I always have the GF or a friend rotate the crank pulley while trying to mate it up. You could try putting it into gear (i'd say a higher gear like 5th so it doesn't spin very fast) and work it in there... I'd jack the rear wheels up though just as a safety precaution.
positron1
The SR dust collar is that fat f****r, you'll need to take it off and get a KA dust collar or cut the SR dust collar.Look how thick that thing is. Your driveshaft is missing by at least a inch due to the thickness of this dust collar. I think the difference has something to do with the USDM and JDM driveshaft's being different somehow?!?!
positron1
Any luck on getting that driveshaft installed? Do you indeed have a SR dust collar?
