He should only need a 2+2 TT driveshaft if he has the TT rear end swapped into his 2+2. If he is still using the NA rear end, a manual 2+2 driveshaft should be what he needs.Ace2cool wrote:No, it will not. The 2+2 and 2+0 have completely different driveshafts. Sorry, but you'll need a 5 speed 2+2 TT driveshaft. Z1 sells a driveshaft SPECIFICALLY for that application.
marty1mc wrote: He should only need a 2+2 TT driveshaft if he has the TT rear end swapped into his 2+2. If he is still using the NA rear end, a manual 2+2 driveshaft should be what he needs.
