nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Sat Aug 25, 2012 7:28 am
Well since you already have the driveshaft, might as well put a NA rear end on it, different gearing.
OR
Someone already put the NA rear end in the car and gave you the driveshaft as hint. You should check it out and let us know. Does the car have HICAS on the rear subframe? Take a pic of the power steering pump, can usually tell that way. Even just a quick look under the rear will tell you what you have. From experience, if you like to take off quick, this would be a good mod for you. At least I am enjoying it.
