Driveshaft doesn't fit ka24de transmission!
bpshonyak
Car: 1989 240sx SE
Hey guys, I recently swapped my ka24e transmission for a ka24de transmission but the driveshaft wouldn't fit back on due to it being about an inch too long. The ka24de transmission is a little longer than the ka24e one, due to the metal circle thing at the end. :facepalm: I own a 89 non-abs 240sx. Do i need a different driveshaft or can I modify something to make it fit? :gapteeth: Your advice is highly appreciated!
ka24e transmission
ka24de transmission
Pento240sx
Car: 1995 Nissan 240SX SE, 1981 Datsun 210 Deluxe, 1981 Datsun 810 Maxima Deluxe and 1999 Infiniti Q45t.
I believe you need to get a 91 to 94 manual drive shaft.
bpshonyak
Car: 1989 240sx SE
So turns out the previous owner decided to remove abs from the car... the diff has an abs sensor that's cut and the drive shaft is also abs. Do I need to replace both? Basically i need to know what combination is compatible with my ka24de transmission? :gotme
blkvrtswp
Car: 93 240SX Convertible
SR20DET FP 20G Turbo
It's been a while since I have played with KA transmissions, but doesn't that round thing just get knocked off the end? Smack it with a hammer / vice grips. I think it just presses in there.
bpshonyak
Car: 1989 240sx SE
LOL never heard of that... can someone else confirm?
Pento240sx
Oh yea now That I remember. When I did the swap I took that ring out. Trust me. If not google is your friend.
bpshonyak
Car: 1989 240sx SE
How'd you take it out? I'm trying but nothings working.
blkvrtswp
Clamp a vise-grip on it and then hit the vise-grip with a hammer. It's just pressed in there in a groove.
