turner »
https://forums.nicoclub.com/turner-u218057.html
Wed Feb 15, 2017 2:07 pm
A couple questions here:
This is for a two piece driveshaft. To a 93 se v6 4x4 standard. The bearing went last year, replaced and failed from poor installation. Then lasted one year and failed again. Just had it replaced under warranty.
1. As I drive it for 30 minutes the bearing is warm-hot to touch, is this normal? As it is already making a friction whining noise in fourth gear 5 minutes into its first drive.
2. What are the chances of a 1996 v6 xe extended cab auto trans. With a two piece driveshaft having the same shaft? And how do I find out or measure it properly?
I figure there could be driveshaft problems or any other ideas I am open to suggestion.
Thanks for such a great forum all!
