driveshaft auto->manual
lenso
Car: 1993 240sx hatch
i have a 92 auto which will get the sr manual treatment. problem is, the clip didn't have the driveshaft. will my driveshaft work or do I need a ka manual driveshaft?
edit: after searching, I found that the manual is different. thus i do need a manual driveshaft. also, theres also the front and rear thing about the driveshaft. which do I need? both?
180fan
Car: 89 fastback
get the mt driveshaft from a junkyard. I paid 70 or 80 for mine. The AT one won't work,on an mt.
Gladius
All you need is the front portion of the driveshaft. And a manual transmission bracket.
lenso
alright, i located a manual driveshaft for $50, but it's for a 1990. will the ka24e driveshaft work? also, the manual transmission bracket....same question as above.
lenso
anyone?
i'll restate it again, will a manual driveshaft out of a 1990 work on my sr swap?
ride4lame
yes
VitaminT
Car: 93 240sx SE
You should be able to use the transmission bracket/crossmember from your clip.
If it is damaged or missing let me know and I will hook you up with the one I have.
