PapaSmurf2k3 »
https://forums.nicoclub.com/papasmurf2k3-u3044.html
Tue Mar 03, 2009 2:51 pm
It really doesn't have anything to do with gravity... but more to do with the angle on the joints in the driveshaft. The more angle you have, the more stress gets put on the joints, and the less efficient the driveline comes. I THINK you can run UP TO about 30 degrees, but you might need to look into special U-joints or something at that point. I've seen some intense angles on trucks.
