Driveshaft and Differential
TheRipper
Car: 93 Nissan 240sx SE R.I.P. & 90 Nissan 240sx
I have a 93 240, has the stock KA24DE in it and I was wanting to swap a RB20 into it. If I bought a motor along with a transmission, what kind of drive shaft and differential would I need?
gr8bryt
Car: 2003 Infiniti G35 Coupe 6-MT
1994 Toyota Camry V6 (Sold)
90 240SX SE Hatchback (Sold)
90 240SX SE (R.I.P--12/24/2007)
You will have to get a custom shaft made for your project. More than likely the same path as doing an rb25 swap.....the rb transmission output to the 240 diff. input. If you didn't already catch it, you can keep your current diff, just install a good lsd.
After reading that, I'm leading you to believe that you can mate the two oem parts together, when I really mean just use them for reference when getting your new shaft(aluminum)
iwantasileightysr
Car: 91 rps13
arent there enough of these swaps being done for a company to start making these driveshafts?
gr8bryt
Yes actually there are a few that make them, you just have to know whom to call on. If memory serves correctly, this should be a good starthttp://mckinneymotorsports.com/
