Peter,Peterofdevon wrote:Guys,
In anticipation of my vibration solution I'm on the lookout for the above. I saw a fellow NICO member parting out his Q a while back in NJ. Drop me an email if you see/hear of the above.
[email protected]
Peter of the three Qs
Especially in labor charges when you install wear items with a shorter life than new! Go new on the driveshaft, and find the best drivetrain balance shop in your area.DrewQ45 wrote:Peter,
I see nothing wrong with getting a used drive shaft providing that you get it cheap...so cheap there's not much to lose if it doesn't work. ... These car will nickel and dime you to death if you're not careful.
...Drew...
Maxnix... would you say it was worth it one picked up a used shaft for say... 20 bucks and installed it him/herself (which is what I meant)? For 20 bucks, it may last the life of the car since we already have high mileage vehicles. If vibration is still present, try another or buy new. The used shaft I pulled was a whopping $13 with the environmental fee and taxes included. Had I not ripped the boot, I would most likely be happy with it.maxnix wrote:Especially in labor charges when you install wear items with a shorter life than new! Go new on the driveshaft, and find the best drivetrain balance shop in your area.
Why change the differential? Is it abused?
You do make a valid point... That is, IF you have the time. If you compare the $450 i spent on my driveshaft, you could buy 9 driveshafts at $50 a piece and see what works best.. Certainly one would think that you would get it right somewhere in there...... I personally got sick of vibration, and decided to buy new..... and its still not completely cured!!!DrewQ45 wrote:Maxnix... would you say it was worth it one picked up a used shaft for say... 20 bucks and installed it him/herself (which is what I meant)? For 20 bucks, it may last the life of the car since we already have high mileage vehicles. If vibration is still present, try another or buy new. The used shaft I pulled was a whopping $13 with the environmental fee and taxes included. Had I not ripped the boot, I would most likely be happy with it.
To each his own....
..Drew...
Chances are very slim a used one will last long. To do it correctly (indexing, balancing and shimming) is time consuming. And if any of the three motor mounts are wonko, it will never be right. But as Q45tech says, "Member's standards vary."DrewQ45 wrote:
To each his own....
..Drew...
