driverside side markers not working
TDS
Car: 2008 G35
Ive had my 240 for over a yr now and i never noticed the side markers lit when the lights were on. I thought they were just reflectors. After talking to a friend about side markers and I showed him mine, i realized that only the right side(passenger) front and rear side markers work. The left side markers remain off.
What could cause this? is there seperate fuses for both sides or for individual side markers or could it be that BOTH lights on the driverside sidemarkers are burnt out? Thanks for the help.
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
My money is on burnt out bulbs.
sleepyRPS13
Car: to sleep
my bet is a squirrel chewed off the wire.
TDS
Car: 2008 G35
ok ill look into the condition of the wires and then replace the bulbs if it is still not solved.
nissan_s15_240sx
Car: '92 nissan 240sx with s15 silvia front end conversion
You might want to also check the conector for both lights.iIf the contacts are coroded or something like that, you might want to sand them a little and put some contact grease in there.
