Driverside doorlock problem
General discussion area for the L30-chassis Altima
240Xtrm
First time owner of a 2001 Nissan Altima SE with a problem on the driverside doorlock. The switch will still lock and unlock all the other three locks, but not the driverside. If I were to lock and unlock with the key from the keyhole on the driverside door, it will do the same for all other three locks. The only way to lock and unlock the driverside is manually or with the key from the outside. Samething with the factory remote, and only the other three locks will unlock and lock. Does this mean I need a new solenoid for the driverside lock? Where to buy one, how much, and is it a PITA to install it?
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
I say door lock actuator has died. Dealer or used but you can never cound on used. You will have to remove the inner door panel to access the actuator.
youngdustin
Car: 99 Altima
240Xtrm, did you ever fix this? I have the same problem and am thinking that Reverend D is right that it is the actuator, but wouldn't mind confirmation before I tear my wife's door panel apart.
Return to “2nd Generation Altima Sedan (1998-2001)”
