Driverside door lamp lost power, but room lamp fuse not blown, need help! :(
DORIMON
All of the other lamps including the 3 other door lamps and dome lamps are still fully functional, but not the driverside. Looks like the wire going to the driverside door lamp may have a short. How far do I have to trace the wire to replace it or what is required to restore power all the way to that lamp?
Ozzie
Car: '90 Nissan 300ZX twin turbo - 2 seater
'99 Mitsubishi Legnum VR-4 Type-S twin turbo
'71 TA22 Toyota Celica (flat light)
'06 MK5 Golf tdi
and some motorbikes too
I know this may sound dumb, but have you checked to see if the globe has blown?
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
ozzie! wrote:I know this may sound dumb, but have you checked to see if the globe has blown?
I second this, its almost always the simpler solution blown bulb versus shorted wire.
BTW Ozzie I had to read your post a couple of times trying to understand what you meant(globe=bulb) -then I checked your location!!
Q451990
Also, be sure to check the door switch...
Heath
