Drivers side window won't work...
240sx_megasquirt
Car: 98 GST Spyder, 95 Probe(12 PSI MSExtra), 93 240sx coupe
My driver side window will not go up or down! The only thing I did was take the switch from the Pass side off so I could get the panel off. I did try to make the window go up via the drivers side switch, but either switch will only work when both are pluged in. So, when I hooked everything back up to get the windows up, only the pass side would work via either switch! So I jumpered the drivers side window to get it up for now. I have check all fues/relays and all is OK.
Please help!93 coupe SE
tx2gman
Car: 95 240SX SE
It could only either be your master switch or your driver side window amp. Sometimes my master switch acts up now and then. I can get the passenger window to go up/down, but I have to play around the switch to get the driver side up.
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
+1 for the window amp.
