drivers side window...
GiLLT
Car: Nissan Versa S
As of yesterday when i click the button for my window to go automatically up it won't i now have to hold it and when the window reaches the top it makes a clicking sound and the inside door paneling slightly moves outward. What happened?
proxim2020
Let the window all the way down. Hold the up button until the window is closed then an additional 4 seconds. Then use your auto-down and try to use your auto-up to see if it works. The clicking I've never experienced. My side panel does move a little bit once the window has closed
GiLLT
Car: Nissan Versa S
Thanks a lot holding it the additional few seconds makes it go auto-up again and the clicking stopped very odd. Good to know if it happens again.
Ever Victorious
Car: '08 Kia Spectra 5
'73 AMC Hornet
Nissan uses a timed auto-up mechanism, so if the timing was off I suppose it could cause the clicking.
Scuba Steve
Car: 2007 Nissa Versa 1.8SL Technology Pakage 6 Speed, Black
Just wondering the auto up works for the drivers side, BUT can you enable the auto up for all the other windows???
Ever Victorious
'73 AMC Hornet
Nope.
It's just not designed to do that. The proper equipment is installed in only the driver's door, and the BCM is programmed only to have an auto up/down on that one window.
proxim2020
I think it's best the way they've designed it. This way the driver doesn't use the auto up on the rear windows that a little arms, hands, and necks may still be hanging out of.
blackversaatl
Car: 2007 Nissan Versa S
Thanks proxim2020! I was wondering what happened to my driver's window auto up too.
You will have to do this if you disconnect the battery. After I installed my CAI, that's when I noticed my auto-up stopped working (when I disconnected the battery).
TweeKeer
Car: Nissan Versa 1.8S (demo)
proxim2020 wrote:I think it's best the way they've designed it. This way the driver doesn't use the auto up on the rear windows that a little arms, hands, and necks may still be hanging out of.
Thankfully if there's any pressure on the window while it's going up it'll stop and go back down.
Ever Victorious
'73 AMC Hornet
"Any" isn't the word I would use. There is a certain threshhold of pressure that is designed into any given window mechanism, and only if this amount of pressure is met or exceeded will the window reverse.
Granted, this is a lot less pressure on newer cars than it used to be. I could probably cut off the circulation in my arm using the Legacy. On the V, simply the weight of my arm was enough to reverse it.
