drivers side mirror 2005 xterra off road
snowbunnymelis
Car: 2005 Nissan Xterra Off raod
first of all, is it really difficult to install?
and next where is the best place to buy it (nissan wants 220) I want it to have power, and look the same...but i need help with options
StephenG
Car: 93 Nissan Hardbody 2wd KA24E 5spd
87 Nissan 200sx CA20E 5spd
You might be able to find one at a local wrecking yard. You'll have to bring your own tools to take it off but you can probably get one for less than $50 I would guess. I'm not familiar with how that model mounts, maybe someone else has some advice in that department.
Also, welcome to Nico.
RT22
Car: 1991 nissan hardbody
Junkyard for sure and go to www.courtesyparts.com and look up truck model for exploded view of the mirror and mounting points. That may show you what all is holding it on and then you can see what needs to be removed to replace it.
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
Start watching Ebay. They'll come up.
As for the install, on the D22 (up to 2004) you had to remove the door panel, and then 2-3 bolts and unplug the connector. I'd bet it's about the same on the newer models. About a 15-20 minute job.
