drivers side low beam not working Canadian 2002 Pathy SE
forlon4
Hi everyone , problem is that the low beam hedlight is not working on the drivers side . Bulb is good and has been replaced anyway.low power daylight running light works as does brights but no regular low . fuses check okay . I'm thinking that it's the daylight running box , where is this , and anyone know how much these units run for , or have I missed the boat and should be looking elsewhere . All help appreciated Thanks . P.S. where can we get a service manual ?
nnorton44
Car: 2001 QX4
Check out this thread:
zerothread?id=456825
JonathanPrem
Car: 02 Nissan pathfinder 4WD SE
I think theirs a fuse you need to replace. I had this problem once and shop put a new fuse in and it worked. It should be near the battery.
forlon4
great link thanks a bunch ! Do you have any idea where I can find a service manual?
forlon4
Thanks for the post but the fuses as said have been checked and bulb replaced .
Pwnin O'Brien
forlon4 wrote:great link thanks a bunch ! Do you have any idea where I can find a service manual?
The following link will take you to the page containing all of the sub-sections of the factory service manual for the 2002 Nissan Pathfinder. The specific file you will need to look in for the DRL module is in 'el.pdf'.
2002 Pathfinder FSM
