Drivers side fog lamp out....
FirePathFighter46
Car: 2001 Pathfinder LE
The assembly was damaged when I purchased my path. The light worked, stopped working before I replaced it, and I thought it was a bulb issue. New assembly new bulb, still no working fog lights.
Any ideas?
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Welcome to NICO!
Open the hood with the ignition on and try to turn on the fog lights. Do you hear a relay click? If not, try temporarily swapping the fog light relay with the A/C relay and retest. Also check for a fog light fuse behind the coil tray.
FirePathFighter46
Yes I hear a clicking. What's that mean?
Towncivilian
The relay clicking means the fog light fuse & relay are both operational. There is a problem in the wiring between the relay and the fog lights, or a burnt out bulb. Test for voltage at the fog lamp harnesses using a voltmeter.
