Drivers side carpeting is wet, all the time, whats going on?
LugNutZ
Car: 04 SentraSER Spec V 01 Pathfinder SE
Whats going on fellas? Im fairly new to Nissan (Honda at heart, I know flame away! ) so bear with me...
The front drivers side floor is always wet. It has rained off and on for a couple days now, so I assume its a drainage issue... Its an 01 Pathfinder 3.5SE... Has anyone else around here had an issue like this?
Any help is appreciated..
I havent had a chance to look under the truck, but Im changing the oil this weekend so ill see if I can spot anything that looks alarming... -Oh how I love changing the oil on a truck, I dont have to worry about jack clearance issues
Any help is appreciated!! Take it easy! Oh, and go LAKERS!!
Modified by LugNutZ at 5:42 PM 3/20/2008
SnowSurfLax
Car: 1999.5 Infiniti QX4
2006 Infiniti M35 Sport
Do you have a sunroof? It's likely the drains are plugged. I think they have them regardless. Can't be sure though.
Nothing wrong with hondas! Just the posers who try to "tune" them and make them look like rice-mobiles. They're good cars that bad people give a horrible reputation.
LugNutZ
Yes I do have a sun roof... I figured thats where the drainage issue was coming in.
Anyone know where and how to check the sunroof drains on this truck?
I hear ya about the honda thing... mine was clean and quick(for a 1.6 liter)
Thanks!
Bump^
Buzzman
Car: 2016 Lexus RX 350
2023 Kia Stinger Elite V6 AWD.
I have an 02 Pathy, and I have had the same problem as well.I wrote about this issue last year on this forum, and there was no consensus on where the leak was. You could try a search for this topic. Good luck with that. I never have had much luck with the search function on this site. Anyways, apparently, the problem is more common than I thought. I wasn't the only one at the time with this issue.I'm not even sure I completely fixed it, or how. I used a garden hose to narrow down the source of the water. I then went across the top of the firewall and beneath the windshield and sealed every little crack and hole I could find. I also drilled a small drain hole under the kick plate on the passenger side to drain any water. Seems to have worked. I also make sure all the other drain holes under the truck are not blocked.Good luck.
LugNutZ
Thanks for the info.
Anyone know a place to find a good diagram of all the drain holes?
LugNutZ
bump, anymore ideas?
SnowSurfLax
FSM? I think you can download it off here somewhere...
